Hello Guest it is October 21, 2026, 02:40:19 AM
Author Topic: 4 th axis rotation  (Read 33383 times)
Re: 4 th axis rotation
« Reply #10 on: January 05, 2013, 05:39:27 PM »
I look at the rotation choices on the general config page there three options which do i want or am i looking in the wrong area ?rot 360rollover, angle short rotation on go ,rotational soft limits
« Reply #11 on: January 05, 2013, 05:44:07 PM »
Make sure this is set to angular, see pic.
Also you will likely want the 360 rollover but depends on how you will work.
« Reply #12 on: January 05, 2013, 06:05:08 PM »
That is checked so I'm not sure what is going on has to be something wacky with the motor I tried 35.55 in steps it almost seemed that
this was closer that the other numbers I tried. God bless you for all your help and patience !
« Reply #13 on: January 05, 2013, 06:07:44 PM »
If you attach your xml I will take a look and see if there is an issue with it.
Are you sure your belt drive is 40:1 reduction as that seems quite a lot for a single belt reduction, would mean your driven pulley would have to have 40 times more teeth than the driver pulley.
« Reply #14 on: January 05, 2013, 06:09:06 PM »
Sorry my mistake you said two belts ::)
Even still thats quite a reduction.
« Reply #15 on: January 05, 2013, 06:13:11 PM »
No it's only one belt
« Reply #16 on: January 05, 2013, 06:15:00 PM »
So that would mean if your driver pulley had 10 teeth your driven had 400? Seems a lot.
« Reply #17 on: January 05, 2013, 06:19:11 PM »
No the main pulley has 40 and the small pulley has  10 and the belt is 40 teeth
« Reply #18 on: January 05, 2013, 06:20:14 PM »
Ah ok so 4:1 reduction that means the 35.55555 is the correct number :)
« Reply #19 on: January 05, 2013, 06:24:54 PM »
I'm going to work more with this tomorrow . I truly appreciate you help so tomorrow I will use the 35.555 when I used this number it seemed that the rotation was rather slow.
