Hello Guest it is October 20, 2026, 06:44:44 PM
Author Topic: Mach Turn Index Pulse and IPR question  (Read 61552 times)
Re: Mach Turn Index Pulse and IPR question
« Reply #40 on: January 15, 2013, 01:02:38 PM »
 I thought it was linear but after getting the VFD settings straightened out it was clear that the 0-10V output is actually rather chaotic. Guess I'll just live with it for now and look forward to the release of Mach4 Turn some time in 2074....
SG
« Reply #41 on: January 15, 2013, 01:06:17 PM »
I know Mach can output a fairly linear PWM as the CSMIO uses it and its very close right the way through the rev range on my wee lathe so it could be controller you are using.
I think you are being a bit optimistic with your release date, if it had been a mill then possibly, lathe no $%£^& chance.
