Hello Guest it is November 22, 2026, 08:11:45 AM
Author Topic: what pendant?  (Read 20557 times)
Re: what pendant?
« Reply #10 on: January 01, 2013, 09:38:58 AM »
Which model you need is up to you. I got the P1A-S and I am very happy with it. I had a Xbox controller before and for simple jogs it was great but for anything needing precision (ie setting offsets) it was out of it's element.
Good luck,
Chris
Offline Fastest1
  •  920 920
  • Houston, TX
what pendant?
« Reply #11 on: January 01, 2013, 09:43:36 AM »
I should have been more clear. Mine is a Shuttle Pro 2 also. It is the outer rings functionality that I like most. The rest about durability, comfort of use and resistance to swarf or coolant are all valid points and would be more so if I was in a position to actually manufacture something.
