Hello Guest it is October 30, 2026, 05:17:23 AM
Author Topic: Laser cut titanium handcuff ring  (Read 72102 times)
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #10 on: December 23, 2012, 08:45:20 AM »
I want that airplane flight security ring knife survival tool! Great work.
Re: Laser cut titanium handcuff ring
« Reply #11 on: December 24, 2012, 05:41:11 AM »
Thanks for posting and the rings are certainly interesting.
« Reply #12 on: December 26, 2012, 01:40:53 PM »
Here's a new one from today.  Simple, yet very different.  My wife wore it this morning and get a comment on it at the first place she went to.
Bruce Boone
Boone Titanium Rings
« Reply #13 on: December 27, 2012, 03:31:55 AM »
Hi Bruce,
Fantastic work you do with those rings! Thanks for posting. Curious what laser does it take to cut these?
« Reply #14 on: December 27, 2012, 04:12:09 AM »
Some wild pieces, Bruce, just amazing work you have done!
« Reply #15 on: December 27, 2012, 04:35:54 AM »
Dan, it's a 4500 watt fiber laser.  I built it onto a Tormach machine and use the Mach 3 control.  It can cut through at least 7mm of titanium.
Bruce Boone
« Reply #16 on: December 27, 2012, 09:18:51 AM »
Thanks, Bruce. Sounds like an impressive laser cutter.
« Reply #17 on: December 27, 2012, 03:45:51 PM »
I can't believe the first comments were about cutting the ring off rather than asking about the laser. As long as you have the tiny key on you then no problem! I wear a plain titanium wedding ring but won't worry about needing it cut off.
Fiber lasers are amazing. Maybe in a few years there will be cheap Chinese versions that us hobbyists can afford.
« Reply #18 on: February 25, 2013, 05:15:07 PM »
Here's another new one.  The chain goes around a tiny sprocket and is driven by the thumbwheels.  The chain wraps around and travells in the groove going around the ring.  It's a fun fidget ring.
Bruce Boone
« Reply #19 on: February 25, 2013, 05:20:19 PM »
Now, that is just neat.  I dont wear jewelry of any kind but I would probably wear that one out.   Do you have a link to order these  and repair bushings/bearings for the thumb wheel ?  ;D
