Hello
Guest
it is
November 13, 2026, 12:31:58 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Testing parallel port output with a multimeter
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Testing parallel port output with a multimeter (Read 44609 times)
Chaoticone
5,624
Precision Chaos
Re: Testing parallel port output with a multimeter
Reply #20 on:
January 29, 2007, 12:54:16 PM »
OK, change it back. one thing eliminated.
Logged
If you could see the things I have in my head, you would be laughing too.
Chip
2,055
Gainesville Florida USA
Reply #21 on:
January 29, 2007, 01:02:39 PM »
Hi, Cristobal
Try this XML it's yours, your Port1 is set Back to 378 std port for #1 and your Dir / Step ports are set to 1 now.
Give it a Try, Chip
Logged
Cristobal
Reply #22 on:
January 29, 2007, 03:43:22 PM »
Bingo! I'm psyched. Thank you. I needed to set the step/dir pins to port 1. That's all. It even works on my other port at CEE8 which is great. Thanks for all your help. Don't worry though, you haven't seen the last of me and my stupid questions!
Logged
Reply #23 on:
January 29, 2007, 03:48:44 PM »
Dont understand that as the xml you posted had the step/dir port set as 1 already. Oh well who cares as long as you are running, now you can start the real fun :-)
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
