Hello Guest it is October 20, 2026, 08:47:34 PM
Author Topic: How to? Long accel/decel profile  (Read 32652 times)
Re: How to? Long accel/decel profile
« Reply #10 on: November 29, 2012, 04:42:18 PM »
 I think you would be better served with another solution.
Just a thought, (;-) TP
« Reply #11 on: November 29, 2012, 05:31:41 PM »
Is my math right? Off the top of my head, that seems to be somewhere upwards of 75,000 inches/minute? Accelerating at something like 600G? As 1G would get you about 125" in 1/2 second.
« Reply #12 on: November 29, 2012, 05:36:04 PM »
80feet per second = 960inches * 60 seconds = 57600 inches per minute
80 feet/sec = 4800 feet/minute * 12 inches per foot = 57600
54.54 mph
80 feet /sec = 2.49 G
Based on my Convert Program
« Last Edit: November 29, 2012, 05:45:53 PM by Ya-Nvr-No »
« Reply #13 on: November 29, 2012, 06:13:09 PM »
Black Powder for the accel. ....... and a Bale of Hay for the decel.  ;D
Not exactly sinusoidal, but it would be hard to see the difference.
Russ
« Reply #14 on: November 29, 2012, 08:03:23 PM »
Assuming my math is correct:
         80   f/sec   =   960   in/sec
         5000   rpm   =   83.33333333   rev per sec
Assuming a   4   in dia pulley   12.5664   inch circumference
         1047.2   in/sec
         87.26666667   ft/sec
         7500   rpm   =   125   rev per sec
Assuming a   2.5   in dia pulley   7.854   inch circumference
         981.75   in/sec
         81.8125   ft/sec
Good Luck
« Last Edit: November 29, 2012, 08:13:13 PM by Ya-Nvr-No »
« Reply #15 on: November 29, 2012, 10:05:27 PM »
You have to accel AND decel to a stop in that one second, so you need to go much faster than the 57600ipm. I guessed at 75,000. Accel goes up as well.
« Reply #16 on: November 30, 2012, 06:30:59 AM »
No doubt, Send us a video clip on first test. LOL
« Reply #17 on: November 30, 2012, 08:40:37 AM »
Not sure why this wasn't more clear yesterday, but if you're going half the ditance, the velocity just doubles, if accel is linear. So, it's 115,200ipm, accelerating at 96G. He wants an s-curve accel, so it will actually be higher than 96G, I've seen a linear stage accelerating at 3-4G, and it's so fast you almost can't see it move.
« Reply #18 on: November 30, 2012, 08:49:46 AM »
Guess I am lost by how you are getting the 96G's
115200ipm = 160fps = 4.973g from my convert program.
Help out an ole toolmaker. LOL
« Reply #19 on: November 30, 2012, 09:33:43 AM »
The online calculator I was using was broken (sort of. ;) )
Your right, but you have to double it to get to 115200 ipm in 0.5 seconds. So it's a little less than 10G. Still pretty damn fast.
