Hello Guest it is November 27, 2026, 08:57:13 PM
Author Topic: Updated Plugins..  (Read 13445 times)
Updated Plugins..
« on: November 26, 2012, 08:10:18 AM »
I would like to see updated plugins that are comparable with newest version of Mach3. The "Video WebCam Point Cloud Scanner" does not not start under Version R3.043.046 and the 3D Laser Scanner by Tom Hubin work only partially. Either/or of those updated/upgraded plugins would be much appreciated!..  ;) :)
Re: Updated Plugins..
« Reply #1 on: November 26, 2012, 12:59:24 PM »
The problem is that MOST plugins are volunteer contributions and unless the author decides to upgrade them there is not much chance of it happenning.
The authors control the source code and without it not much can be done.
Just a thought, (;-) TP
« Reply #2 on: November 26, 2012, 02:57:14 PM »
Thanks for quick replay. As I understand it Tom Hubin posted it here:
"Hello Haik,
Here is a link to my 3d Video Probe plugin for Mach3, along with Open Source Code.
http://www.machsupport.com/forum/index.php/topic,10959.msg74212.html#msg74212
Tom Hubin
thubin@earthlink.net"
« Reply #3 on: November 26, 2012, 04:06:51 PM »
There you go now all you have to do is HIRE someone to modify it the way you want it.
