Hello Guest it is October 02, 2026, 02:51:32 AM
Author Topic: Go To Zero "Z" last?  (Read 10295 times)
« on: November 06, 2012, 11:43:47 AM »
Hi, I'm having an issue with my CNC.
When I hit "Go To Zero" the machine moves the "X" and "Y" simultaneously to zero, then it will move the "Z" axis to zero.
I would like the "Z" to go to zero first, then have the "X" and "Y" move.
Can anyone help?
Offline alenz
  •  137 137
Re: Go To Zero "Z" last?
« Reply #1 on: November 06, 2012, 03:08:36 PM »
Go to Config > Safe_Z Setup and select ‘Allow Safe_Z Moves’. Now Goto Z should move Z to the value entered in the Safe_Z box, then move X and Y to zero, and finally move Z to zero.
Al
Can anyone help?
« Reply #2 on: November 06, 2012, 03:11:17 PM »
Thanks, just figured it out
« Reply #3 on: November 06, 2012, 03:44:13 PM »
The reason it IS the way it is . You would never want to put Z at zero(top of material BEFORE you move XY into position.
Just a note make sure you understand HOW you have SafeZ setup. It can get ya when you are not looking.
Just a thought, (;-) TP
