Hello Guest it is November 13, 2026, 11:32:22 AM
Author Topic: Mill set-up problems.  (Read 7911 times)
« on: November 02, 2012, 10:18:43 AM »
Hello,
I work for Conduit Projects in Boston, here we have been using mach3 for years to control a big router and recently we picked up The Little Machineshop's mini-mill and converted it to a CNC with the idea of using mach3, however we're encountering a few problems.
Currently, the licenced copy of Mach3 is just stopping half way through our test parts, sort of inexplicably. Also, the visualizer seems to not be representing the z coordinates, squishing them down in to the x and y plane. My boss is more of the expert on this than I am, but whatever information you need I can ask him and he can give it to you best he can.
All the motors and control box are functional, we're running a xylotec 4 axis controller, nema-23 motors on a solidstate computer that has 2gb of ram and an intel atom d2700 quad core processor. I'm sure its just some strange or silly setting we're missing.
Thanks!
Tom
  •  9,377 9,377
Re: Mill set-up problems.
« Reply #1 on: November 02, 2012, 11:32:56 AM »
Hi Tom,
If you are only being allowed to run up to 500 lines of code then it may be to do with your license. Perhaps check with Scott at license@machsupport.com to verify that it is valid.
I am not sure exactly what you mean about the visualizer squishing the Z coordinates.  ???
