Hello Guest it is November 13, 2026, 04:59:14 PM
Author Topic: Can the Pokeys PWM outputs be used to emulate a DAC?  (Read 12720 times)
« on: November 01, 2012, 12:56:47 PM »
The subject says it all really.
Will the PWM outputs, with a suitable series resistance and load (with a capacitor to provide smoothing) give me the equivalent of a DAC output?  I just want an easy way to drive a 200mV digital meter to use it to display a value generated by my pokeys56e.
Further to that can I read an A2D input and feed the result out to one of the PWM outputs using the supplied software?
Offline NeoTO
  •  504 504
    • PoLabs
Re: Can the Pokeys PWM outputs be used to emulate a DAC?
« Reply #1 on: November 16, 2012, 12:59:20 AM »
Apparently I missed this topic, so this is coming a little bit late...
Yes, you can use PWM outputs with an appropriate RC low-pass filter to simulate analog inputs. You can even try to hook up a digital meter directly to PWM outputs as some of the meters already have a low-pass filtering built-in.
You can assign a value of the analog input to an unused Mach3 DRO register and use the same register as the duty cycle of the selected PWM output.
