Hello Guest it is August 15, 2026, 12:35:45 AM
Author Topic: Reset at the end of an M6 macro  (Read 9459 times)
« on: October 27, 2012, 04:21:27 PM »
Hi
I've been trying to debug the toolchanger on my little emco lathe. I've got it to the point where it moves to the correct position and then starts to reverse (all correct) but then Mach resets every time.
Is there anywhere that Mach stores the reason for the current reset trip as I'm not getting any visible error message in the display. It would be nice if there was a clue in there somewhere.
Paul
Re: Reset at the end of an M6 macro
« Reply #1 on: October 27, 2012, 05:21:49 PM »
Noise? Try setting a high debounce interval to see if it helps.
« Reply #2 on: October 31, 2012, 05:25:37 PM »
Thanks Hood.
That improved things a lot. I can see some areas where noise is creeping into the setup and am taking measures to minimise it.
A bit more tinketing and testing should see it all finally working.
All the best
Paul
« Reply #3 on: November 01, 2012, 03:15:19 AM »
Hopefully you will figure it out :)
