Hello Guest it is September 06, 2026, 02:05:09 AM
Author Topic: rotary axis has stops moving  (Read 12052 times)
« on: October 19, 2012, 05:31:47 PM »
Hi
I am a new user and I have a rotary axis (a) that seems to have a limit.  I can go so far then it stops and only allows me to go the opposite direction.
What settings do I need to change to make it rotate indefinitely.
Any help would be appreciated.
Re: rotary axis has stops moving
« Reply #1 on: October 19, 2012, 06:31:03 PM »
Sounds like you may have a soft limit set for the A axis .
« Reply #2 on: October 20, 2012, 03:37:39 AM »
Yes as TP says you likely have the rotational; soft limits enabled, you will find that option on General Config page near the lower middle right section of that page.
« Reply #3 on: October 20, 2012, 01:05:22 PM »
I will have a look
« Reply #4 on: October 22, 2012, 10:02:41 AM »
Hi I turned off the rotational soft limits and restarted the software.  It did't change.
« Reply #5 on: October 22, 2012, 02:40:57 PM »
Can you attach your xml and I will have a look.
