Hello
Guest
it is
October 24, 2026, 02:49:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
switching from metric to inches temporarly
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: switching from metric to inches temporarly (Read 12863 times)
trparker
72
on:
October 11, 2012, 04:32:50 PM »
My machine is set up for Metric I want to run a program in inches
I do not want to change the whole Mach 3 set up
what is a better way to change from metric to inches for this run...
I tried finding this in the videos but ran out of patience
thanks
Carnoustie, Scotland
Re: switching from metric to inches temporarly
Reply #1 on:
October 11, 2012, 04:51:47 PM »
Have a G20 in your code and Mach will run it in Imperial units.
trparker
72
Reply #2 on:
October 11, 2012, 04:58:42 PM »
You mean if I run a G code that is written in inches
my machine will automatically run it in inches
even though it is set up for mm.....
Reply #3 on:
October 11, 2012, 05:07:44 PM »
As long as the code tells Mach it is written in inches, ie it has a G20 at the start then Mach will run it correctly.
trparker
72
Reply #4 on:
October 11, 2012, 05:16:19 PM »
Here is the file I am running
It seems to have a G20 at the beginning
is this what you're talking about ??
thanks I sure appreciate it!!!
Reply #5 on:
October 11, 2012, 05:20:27 PM »
Yes, that should run fine. The DROs may display Inch or mm, that will depend on what you have for the setting for DROs in General Config, you can lock them to native units or have them change, I personally prefer them locked.
trparker
72
Reply #6 on:
October 11, 2012, 05:24:39 PM »
Hey thanks you've been a great help
Reply #7 on:
October 11, 2012, 05:26:56 PM »
No problem
Print
Pages:
1
Go Up
« previous
next »
