Hello Guest it is November 13, 2026, 01:54:23 PM
Author Topic: DRO problem???  (Read 35401 times)
Re: DRO problem???
« Reply #10 on: October 08, 2012, 11:32:25 AM »
So, the value box is close, but still not accepting the "000" (multiple).
Here is the code
Code: [Select]
' Macro for consecutive S/N engraving from MACH
Main
End
Sub main
Dim A As String
Dim Ch As String
Dim Cnt As Integer
Dim Value As String
SetVar(1303 , .250)  'LetterSpacing
Setvar(1300 , -0.005) ' Z Depth cutting
Setvar(1200 , 0.050) ' Safe Z
'CPx= Getoemdro(0)
'CPy= Getoemdro(1)
SETIJMODE(1)
Setvar(1301, getdro(0))
Setvar(1302, getdro(1))
Value = Question( "What is the value ??" )
Message(Value)
A = Value
For Cnt=1 To Len(A)
  Ch=Mid(A,Cnt,1)
  Select Case Ch
    Case "0" ZERO
    Case "1" ONE
    Case "2" TWO
    Case "3" THREE
    Case "4" FOUR
    Case "5" FIVE
    Case "6" SIX
    Case "7" SEVEN
    Case "8" EIGHT
    Case "9" NINE
  End Select
Next
I defined "value" as a string, but it's still not accepting multiple "zeros"???
Any thoughts?
Mike in MN
Re: DRO problem???
« Reply #11 on: October 08, 2012, 11:34:16 AM »
IF you could post the Macro code it would be much easier to help.
Re: DRO problem???
« Reply #12 on: October 08, 2012, 11:44:02 AM »
Attached is the M1502
Basically everything after what I added in the other post is just g-code.
It works flawlessly if there is no leading Zeros (all real numbers).
Thank you,
Mike in MN
Here is the code in the attached file (The g-code is incomplete as of right now with regards to the "Zs" I will absolute code them.)
Code: [Select]
Main
End
Sub main
Dim A As String
Dim Ch As String
Dim Cnt As Integer
Dim Value As String
'CPx= Getoemdro(0)
'CPy= Getoemdro(1)
SETIJMODE(1)
Message(Value)
A = Value
For Cnt=1 To Len(A)
  Ch=Mid(A,Cnt,1)
  Select Case Ch
    Case "0" ZERO
    Case "1" ONE
    Case "2" TWO
    Case "3" THREE
    Case "4" FOUR
    Case "5" FIVE
    Case "6" SIX
    Case "7" SEVEN
    Case "8" EIGHT
    Case "9" NINE
  End Select
Next
SETIJMODE(1)
While IsMoving()
Wend
End Sub
Sub ZERO
message "Zero"
Code "G91X.025"
Code "G91X.0419 Y.013"
Code "Z-.2"
Code "G1 Z-.06 F10."
Code "G91G3 Y.0539 I-.0741 J.027"
Code "G91X-.0374 I-.0187 J-.0066"
Code "G91Y-.0539 I.0741 J-.0269"
Code "G91X.0374 I.0187 J.0067"
Code "G0 Z.26"
Code "G91X.0045 Y-.013"
While IsMoving()
Wend
End Sub
Sub ONE
message "One"
Code "G91X.025"
Code "G91Y.0685"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91X.0114 Y.0115"
Code "G91Y-.08"
Code "G0 Z.26"
Code "G91X-.0114"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91X.0229"
Code "G0 Z.26"
While IsMoving()
Wend
End Sub
Sub TWO
message "Two"
Code "G91X.025"
Code "G91X.0017 Y.0685"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G2 X.0444 Y-.0104 I.0205 J-.0123"
Code "G91X-.0059 Y-.0143 I-.0228 J.0011"
Code "G91X-.0206 Y-.0153 I-.1236 J.1441"
Code "G91G3 X-.0196 Y-.0285 I.0186 J-.0339"
Code "G91G1 X.0478"
Code "G0 Z.26"
While IsMoving()
Wend
End Sub
Sub THREE
message "Three"
Code "G91X.025"
Code "G91X.0011 Y.0685"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G2 X.0395 Y.0052 I.0221 J-.0151"
Code "G91X-.0164 Y-.0337 I-.0135 J-.0142"
Code "G91G0 Z.26"
Code "G91X.0057"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G2 X.0119 Y-.0338 I-.0017 J-.0196"
Code "G91X-.0418 Y.0052 I-.0185 J.0222"
Code "G0 Z.26"
Code "G91X.048 Y-.0114"
While IsMoving()
Wend
End Sub
Sub FOUR
message "Four"
Code "G91X.025"
Code "G91X.0414"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91Y.08"
Code "G91X-.0414 Y-.0612"
Code "G91X.0531"
Code "G0 Z.26"
Code "G91Y-.0188"
While IsMoving()
Wend
End Sub
Sub FIVE
message "Five"
Code "G91X.025"
Code "G91X.0484 Y.0801"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91X-.0484"
Code "G91Y-.0355"
Code "G91G2 X.0458 Y-.0045 I.0205 J-.0268"
Code "G91X-.0245 Y-.0401 I-.0214 J-.0145"
Code "G91X-.0213 Y.0114 I0. J.0254"
Code "G0 Z.26"
Code "G91X.0501 Y-.0114"
While IsMoving()
Wend
End Sub
Sub SIX
message "Six"
Code "G91X.025"
Code "G91X.048 Y.068"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G3 X-.0434 Y-.0043 I-.0208 J-.0116"
Code "G91X-.0016 Y-.0457 I.0667 J-.0252"
Code "G91X.0457 Y-.0016 I.0231 J.0057"
Code "G91X-.0457 Y.0016 I-.0226 J.0073"
Code "G0 Z.26"
Code "G91X.0468 Y-.018"
While IsMoving()
Wend
End Sub
Sub SEVEN
message "Seven"
Code "G91X.025"
Code "G91Y.08"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91X.048"
Code "G91G3 X-.024 Y-.08 I.1214 J-.0801"
Code "G0 Z.26"
Code "G91X.024"
While IsMoving()
Wend
End Sub
Sub EIGHT
message "Eight"
Code "g90 G0  Z#1200 X[#1301 + .2250] Y#1302 "
Code "G91X.025"
Code "G91X.0214 Y.0428"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G2 Y.0372 I0. J.0186"
Code "G91X.0237 Y-.0186 I.004 J-.0193"
Code "G91X-.0237 Y-.0186 I-.0195 J.0005"
Code "G91G3 Y-.0428 I0. J-.0214"
Code "G91X.0266 Y.0214 I.0042 J.0219"
Code "G91X-.0214 Y.0214 I-.0214 J0."
Code "G0 Z.26"
Code "G91X.0214 Y-.0428"
While IsMoving()
Wend
End Sub
Sub NINE
message "Nine"
Code "G91X.025"
Code "G91X.0018 Y.0122"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G3 X.0434 Y.0043 I.0208 J.0116"
Code "G91X.0016 Y.0457 I-.0667 J.0252"
Code "G91X-.0457 Y.0016 I-.0231 J-.0057"
Code "G91X.0457 Y-.0016 I.0226 J-.0073"
Code "G0 Z.26"
Code "G91X.003 Y-.0622"
While IsMoving()
Wend
End Sub
SETIJMODE(0)
CODE"G90"
CODE"M30"
Re: DRO problem???
« Reply #13 on: October 08, 2012, 11:48:27 AM »
I see your point I will think about this and get back.
Re: DRO problem???
« Reply #14 on: October 08, 2012, 11:53:28 AM »
Ok, I feel kind of bad going through all of this before looking over the documents...
I changed the "Question" to "AskTextQuestion" per the Macro-Prog-Ref pdf. It works like I want it to now.
I will try using this format and refine the code and see how things work from there.
I do appreciate you giving me the direction.
Thank you,
Mike in MN
Re: DRO problem???
« Reply #15 on: October 08, 2012, 11:56:06 AM »
I was just about to suggest the same change(;-) BUT you beat me to it. The aggravating thing about AskTextQuestion is the operator HAS to manual click on the LINE to be able to input the value. MAJOR pain.
Let us know how it works out, (;-) TP
Re: DRO problem???
« Reply #16 on: October 08, 2012, 12:08:42 PM »
Just another thought, You CAN create your own text box in VB and have it operator friendly AND make it a s large or small as you need. The asktextquestion box was what Art created to make it easier on us.
Re: DRO problem???
« Reply #17 on: October 08, 2012, 12:17:31 PM »
I would be interested if  you have a little direction for the texbox. Can that be incorporated in the "Screen"?
Mike in MN
Re: DRO problem???
« Reply #18 on: October 08, 2012, 12:25:10 PM »
    Begin Dialog DialogName1 60, 60, 160, 70, "Input Serial Number"
        TEXT 10, 10, 28, 12, "SN:"
        TEXTBOX 42, 10, 108, 12, .SNStr
        OKBUTTON 42, 54, 40, 12
    End Dialog
    Dim Dlg1 As DialogName1
    Dialog Dlg1
    MsgBox Dlg1.SNStr
End
It cannot be directly BUT you can add a button to call up the textbox from the screen.  You would save the value to a DRO or variable or possible a user message line.
Re: DRO problem???
« Reply #19 on: October 08, 2012, 12:31:00 PM »
Probably best to Save it to a Gcode Var (SetVar(500, Value) )that way it is directly available from inside the macro. IF you want it to be incremental  you would save it to a VAR in the range or 500-600 that way it is saved when you close down MAch3 and is available when you start back up to continue the SN string where you left off.
At the same time I would write the value to teh MACH3 staus bar so the OP can SEE what he actually typed in to verify it is correct BEFORE he makes a bad serial number.
« Last Edit: October 08, 2012, 12:32:46 PM by BR549 »
