Hello Guest it is November 13, 2026, 12:49:02 PM
Author Topic: i must be totally stupid and dumb  (Read 45393 times)
Offline belin
  •  37 37
Re: i must be totally stupid and dumb
« Reply #10 on: October 07, 2012, 03:29:28 AM »
HOOD
yes ive set my machine and each axis to MMs
« Reply #11 on: October 07, 2012, 03:38:45 AM »
belin, have you checked to see if your machine is moving the proper distance?  If you give it a move in gcode or jog a given distance does it travel that distance?  You can set a ruler on the table to get a good idea.
Offline belin
  •  37 37
« Reply #12 on: October 07, 2012, 03:44:44 AM »
hi brett...thanks for talking with my husband the other night
yes...i can move all axis with the JOG....but as my husband said....there are no limit switches on this machine so it can JOG all the way to the end of each axis....
what i have done though....is in HOMING/LIMITS...i have set the table size less a few CMs so the machine recognises the dimensions of the working are....that way ive found that when i load a G CODE (project) into mach 3 the project is loaded within the table working area and by jogging and resetting the tool path and axis's....the machine works within the bounderies
hey...im getting good at this....RIGHT....lol
its still a nightmare....but not so scary now....
Offline belin
  •  37 37
« Reply #13 on: October 07, 2012, 03:46:58 AM »
ah wait....i see what you mean...
in relation to MMS vs UNIIT size...
yes thats a great idea....i know its moving in increments of 1.000 so im guessing thats 1 UNIT at a time....
god bless me im going to have a victory over this mach 3 programme if it kills me...
did i mention i hate computer programmers....lol
« Reply #14 on: October 07, 2012, 03:48:20 AM »
 ;D
Offline belin
  •  37 37
« Reply #15 on: October 07, 2012, 03:51:10 AM »
BRETT....dont throw SMILES at me just yet...lol
i will admit to breaking out in a tiny grin at times...but i think im far from smiles...
you guys so far have been a great help to me...
like i said....there would be probably 100s og newbie guys on here that really need your information DUMBED DOWN to a level that is understandable to a novice...
hell....i even had to look up VECTOR....lol
  •  9,377 9,377
« Reply #16 on: October 07, 2012, 03:57:27 AM »
Hi Belin,
LazyCam is OK for what it does but it has it’s limitations and quirks (perhaps like all software) and is really not that suitable to use for engraving work.
Most of my CNC work is with laminate engraving and I use Vectric VCarvePro http://www.vectric.com/WebSite/Vectric/vcp/vcp_index.htm which is extremely quick and easy to learn and use although it is perhaps not cheap to purchase. For general engraving work and for the price this software takes a lot of beating.
There are some free alternatives such as F-Engrave http://home.comcast.net/~sskroch/Fengrave/fengrave.html which I have found to be excellent. This software is pretty versatile and has enabled me, from one extreme to the other, to engrave text down to 0.5mm height http://www.machsupport.com/forum/index.php/topic,21525.msg150158.html#msg150158
 as well as V-Carving 12mm deep into Teak (using different spindles for each task, of course).
There is perhaps no easy route to the learning process but my recommendation is start with a simple, basic project, get plenty of ‘hands-on’ experience and spend some time browsing the forum. Once you have mastered the basics you will be surprised at just how easy it all is.
Offline belin
  •  37 37
« Reply #17 on: October 07, 2012, 04:02:33 AM »
TWEAKIE...my god....if you where here i would kiss you...lol
you know exactly what im after....a simple ENGRAVING programme to engrave on flat surfaces...
yes Lamited Surfaces such as GRAVOPLY which is my most common material i use..
you really are your avatar...a SUPER KITTY...lol
Offline belin
  •  37 37
« Reply #18 on: October 07, 2012, 04:04:50 AM »
wait TWEAKIE....before i get into to far
im assuming these programmes you suggested just replace lazycam and can produce simple G CODE...CORRECT...which i just SAVE and load up into mach 3 at my pleaseure
am i reading you correctly
Offline belin
  •  37 37
« Reply #19 on: October 07, 2012, 04:21:27 AM »
TWEAKIE
i went here
and it says i cant open a PY file
anychance of dumbing it down even more for me please...how can i easily get the F-ENGRAVE software to try out
