Hello
Guest
it is
October 21, 2026, 05:52:39 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
New startup
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: New startup (Read 19164 times)
ger21
6,295
Re: New startup
Reply #10 on:
October 18, 2012, 08:45:30 PM »
Sounds like you've got some very bad resonance issues, which can happen often with the Xylotex.
If you have dual shaft motors, adding dampers can double or triple your speeds, and make the motors run much smoother.
See this thread for more info.
http://www.cnczone.com/forums/showthread.php?p=256639#post256639
Logged
Print
Pages:
1
2
Go Up
« previous
next »
