Hello Guest it is November 12, 2026, 04:08:32 AM
Author Topic: CNC Grinder code  (Read 24549 times)
Re: CNC Grinder code
« Reply #10 on: October 02, 2012, 09:55:11 AM »
The search engine with only one search criterea is fairly lame. When you add a second part for search it perks up.
I'll Dig the Screenset/Wizard out and post it here. You may have to finish it out the way you want it. I was just testing the procees for someone to see IF it could be done .
Grinding seems simple but it is actually very complex to do right. Mainly because you are dealing in extremely small moves and the wheel is contintuously getting smaller.
