Hello Guest it is November 13, 2026, 02:03:47 PM
Author Topic: A couple setup problems - 3 axis engraver  (Read 21715 times)
Re: A couple setup problems - 3 axis engraver
« Reply #10 on: October 05, 2012, 01:27:25 PM »
Saving fine here.
Are you using an old version of Mach? Might be worthwhile updating.
« Reply #11 on: October 05, 2012, 02:42:02 PM »
No I just loaded it, but will write over it.  You mean to say when you enter values in dir and step boxes in the motor tuning dialog, , click ok, then come back, they are what you saved previously?
« Reply #12 on: October 05, 2012, 03:28:00 PM »
Yes they save for me.
So you have the latest version of Mach? XML seemed to be an old version.
« Reply #13 on: October 05, 2012, 04:02:21 PM »
Ok fixed it.  The software was old, updating fixed that saving issue.
The lost steps were due to a disconnected cable shield on the axis cable inside the controller box, between the motor driver card and the motor cable output jack.
Nothing like a shield disconnected, acting like an antenna. sheesh.   I think all is well, thanks SO much for the quick help, much appreciated.
