Hello
Guest
it is
October 04, 2026, 03:01:52 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Running Mach 3 on 64 bit for non machine controller
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Running Mach 3 on 64 bit for non machine controller (Read 11232 times)
Hyperlitz
9
on:
September 30, 2012, 08:28:30 AM »
Hi there I am inquiring about any problems running mach on my new windows 64 bit Pro computer this is for cad design and processing only as I have a XP machine for the machine controlling duties. Am I right in thinking that this should be alright or could you point at what I need to do.
Carnoustie, Scotland
Re: Running Mach 3 on 64 bit for non machine controller
Reply #1 on:
September 30, 2012, 09:15:43 AM »
Should work fine.
Hyperlitz
9
Reply #2 on:
September 30, 2012, 09:37:47 AM »
Many Thanks for the confirmation Hood.
Bob.
ger21
6,295
Reply #3 on:
September 30, 2012, 09:47:22 AM »
IF you're just using Mach3 for simulation, be aware that some things won't work properly without the parallel port driver, so you may not get the same results.
Reply #4 on:
September 30, 2012, 10:35:21 AM »
Is that still the case Gerry? Thought nowadays Mach ran in true simulation mode, could be wrong though.
ger21
6,295
Reply #5 on:
September 30, 2012, 09:38:22 PM »
If it's changed I wasn't aware of it.
Print
Pages:
1
Go Up
« previous
next »
