Hello Guest it is September 13, 2026, 04:19:23 AM
Author Topic: VB Script from g-code problem  (Read 38499 times)
Re: VB Script from g-code problem
« Reply #10 on: September 23, 2012, 04:50:50 PM »
Sorry in my code. Ill do that now sorry its very early
« Reply #11 on: September 23, 2012, 04:52:21 PM »
It runs now and still no msgbox. Ive saved the macro under C:\Mach3\macros\MachStdMill\Mill which is the current screenset im using
« Reply #12 on: September 23, 2012, 04:54:45 PM »
It will depend what the profile is called, If that is the profile name you see in Mach then that is the correct location.
Not sure what you are meaning though, are you saying its doing as you want now?
« Reply #13 on: September 23, 2012, 04:55:36 PM »
Ok ive moved it to a few folders now. What it does now is it just pauses on the M-code call and sits there. No message box nothing
« Reply #14 on: September 23, 2012, 04:58:37 PM »
Try it without the (),
Msgbox "Its being called"
« Reply #15 on: September 23, 2012, 05:00:01 PM »
Ok just noticed its the reset, maybe it will not throw the message box if its after a reset, not sure, try with the message box before.
To see which folder you are needing to put it in right click  the shortcut you use to launch Mach abd look at its  properties and see what its target is.
« Reply #16 on: September 23, 2012, 05:01:38 PM »
Does the m-code file go right into the root directory or does it go into one of the macro folders? ive got it in a few places already.
« Reply #17 on: September 23, 2012, 05:02:37 PM »
Ok just tried and it works fine here so I think it may either be the wrong folder or could well be something to do with MSM as its not a standard screenset so it may be screwing with it.
« Reply #18 on: September 23, 2012, 05:03:53 PM »
Ill try load a basic mach screen set and ill save the macro into the macros, macros/mach3mill
« Reply #19 on: September 23, 2012, 05:04:00 PM »
It goes into the macro folder of the profile you are using so if for example the profile you are using is dcattena the location would be
C:\Mach3\Macros\dcattena
