Hello Guest it is October 25, 2026, 05:01:08 PM
Author Topic: I broke it??  (Read 46904 times)
Re: I broke it??
« Reply #10 on: September 16, 2012, 12:00:20 PM »
Neither.  Tried them all (repeatedly!).  I'm so stuck in it, I have to load a different wizard just to 'back out' to the main screen!  :O
The buttons do have the appearance of being clicked, but they do nothing.
Re: I broke it??
« Reply #11 on: September 17, 2012, 10:19:50 PM »
So from a few background conversations going on...  it's looking like a problem with Active X, not Mach or NFS.
Will post more when it's fully resolved.
Re: I broke it??
« Reply #12 on: September 18, 2012, 06:42:19 AM »
Ok, the line you are hitting tries to establish a fileSystem Object. I had not thought about that, but it likely does call outside Mach into some MS stuff. You must be right that its something you deleted from windows  if a clean mach install and a clean wizard instal doesnt fix it.
I am sorry,but I dont have anymore good ideas. Ill see if Brian has any.
Re: I broke it??
« Reply #13 on: September 18, 2012, 07:58:39 AM »
100% total Mach re-install didn't fix it.
Tried to install a VB6 update patch thinking that might install some missing files - it wouldn't run!
Sheesh...  at this rate it might be faster if I just reinstall windows from scratch!  :O
Anyone planning on porting Mach to Mac?  ;)
Re: I broke it??
« Reply #14 on: September 18, 2012, 09:28:19 AM »
Anyone planning on porting Mach to Mac?  Wink
As a matter of fact, yes. V4 is being done with a cross platform tools. I have been trying to get the new wizards to compile on my mac,but no luck yet- actually very little work on it so far, to busy with the win version. Also planed for linux.
Re: I broke it??
« Reply #15 on: September 18, 2012, 10:53:28 AM »
Have you tried a system restore back to before you worked on it(;-)
Just a thought, (;-) TP
Re: I broke it??
« Reply #16 on: September 20, 2012, 10:47:48 PM »
Fixed it!
Wow - what a gong show.
And what any easy fix in the end....
regsvr32 scrrun.dll
Done.  Really!  That was it.
Re: I broke it??
« Reply #17 on: September 21, 2012, 06:58:57 AM »
Happy to hear you found it. How did you do that? Was the .dll still on your machine, just not registered?
Re: I broke it??
« Reply #18 on: September 21, 2012, 07:01:05 PM »
That's what it looks like.
I can only assume that as I was stripping the machine down to it's skivvies, one of those programs must have de-registered (but not deleted) the DLL.
And since I'd taken SO many thing off at once, I had no idea which one was the culprit!
So, I started googling various phrases of the error message.  Came up with a common theme amongst all of them and tried it.
-poof- fixed!
