Hello Guest it is November 13, 2026, 05:02:09 PM
Author Topic: New Pokeys plugin MPG setup help.  (Read 38630 times)
Re: New Pokeys plugin MPG setup help.
« Reply #10 on: November 10, 2012, 04:51:58 PM »
Just an update on this.
Kflop wants to have control of all motion signals. The MPG has to be connected to the kflop for this work. You will all so need to connect the axis and step increments to kflop via switches. It looks like there maybe a work around for the switches but would require some VB script or a brain.
Any it just turned in to more of a hassle then I wanted deal with. I have since pulled my kflop/analog and i'm in the process of switching to a PMDX-126,PMDX-107 and ESS. Cost wise its about the same.
Now there is nothing wrong with the kflop/kanalog, it just doesn't work well with a pokeys as far as motion signals are concerned. In fact the kflop/kanalog I would says is more powerful then a smoothstepper/pmdx solution. Down side is it is not plug-in play.
Hopefully this helps someone down the line when they are shopping for there machine.
-Wes
