Hello Guest it is November 07, 2026, 07:06:06 PM
Author Topic: Execute GCODE without motors  (Read 9439 times)
« on: September 10, 2012, 06:30:01 AM »
Hi,  ;)
I am designing a Simulation Software for Mach3 using the plugin files.  I made a plugin for extract all coordinates of the machine and the tool, and I made a program for show the movements of the milling machine in 3D.
The problem is that the simulation works at the same time that the motors; and I need to run the simulator without the movements of the real machine.
How can I execute a GCode in Mach3, without movements of the motors X Y and Z? I need to disconnect the motors through software.
A lot of thanks!   ;D
Re: Execute GCODE without motors
« Reply #1 on: September 10, 2012, 11:34:50 AM »
You might try the following ... on the MDI screen.
Russ
« Reply #2 on: September 10, 2012, 02:20:56 PM »
Ok thanks!!
I will try it!
« Reply #3 on: September 11, 2012, 04:20:45 AM »
The MDI Input recognises this function Offline (I don't have the Status: Unknown word where unary operation could be), but the motors always works...
« Reply #4 on: September 11, 2012, 04:32:10 AM »
I find a OFFLINE Button in the first screen, and It rules!!!
Thanks!
