Hello Guest it is October 23, 2026, 11:06:14 PM
Author Topic: Mach3 turn atc  (Read 72804 times)
Re: Mach3 turn atc
« Reply #10 on: September 10, 2012, 10:22:34 AM »
lol almost scared to ask anything now as all you guys are clued into this.
ok copied and pasted it v scribt and saved as above file name.
typed t0202 in the mdi bar and nothing, how does mach turn know a axis is my turret.
ducks for cover
Re: Mach3 turn atc
« Reply #11 on: September 10, 2012, 10:35:52 AM »
Hi Jasminder,
You could still use a DC motor and only need one switch running on a cam or an optical switch with a slotted disk.
Re: Mach3 turn atc
« Reply #12 on: September 10, 2012, 10:41:25 AM »
You have to enable the A axis in Ports and Pins and then in Motor Tuning set the number of steps per one turret index. Actually just a bit more than one index so that it overshoots a bit and then reverses to lock.
Re: Mach3 turn atc
« Reply #13 on: September 10, 2012, 10:44:12 AM »
i have done that and set the steps also. will mach3 know i am using that as the turret then
Re: Mach3 turn atc
« Reply #14 on: September 10, 2012, 10:46:36 AM »
Yes. The macro tells it to move the A axis. Go to General Config and under Tool Change select Automatic Tool Change.
Re: Mach3 turn atc
« Reply #15 on: September 10, 2012, 10:50:54 AM »
the macro you posted for me, do i just copy and paste the hole thing, is there anything i need to do with it.
i have tool change set to auto
Re: Mach3 turn atc
« Reply #16 on: September 10, 2012, 10:52:06 AM »
Yes. Copy and paste it in the M6Start.m1s macro file.
Re: Mach3 turn atc
« Reply #17 on: September 10, 2012, 12:01:22 PM »
Hi Jasminder,
I am sorry to say but then how mach3 will get a datum point for let's say tool no. 1.?
jasminder singh
Re: Mach3 turn atc
« Reply #18 on: September 10, 2012, 12:05:38 PM »
one thing about the hellfire's turret i would like to know is that "does it has a worm and gear"? or just a stepper attached by some sort of reduction pulleys + timing belts?
regards,
Jasminder
Re: Mach3 turn atc
« Reply #19 on: September 10, 2012, 12:11:58 PM »
You set it manually to the current tool and then you can check Persistent Tool Selection in General Config and Mach will remember the last tool on a restart. You can add a second switch for homing when you power up the machine.
Of course 4 switches on an 8 position turret would be better as Mach would always know the tool in position, but it's more complex too and requires 4 inputs, although you could even do it with only 3 switches.
