Hello Guest it is October 30, 2026, 08:32:19 PM
Author Topic: Mach3 ignoring safe Z  (Read 19438 times)
« on: September 04, 2012, 09:41:31 AM »
Hi guys,
I have been using Mach3 for over a year and all of a sudden, it is ignoring the safe Z. Is the safe Z across the board in all modes? IT is set for .5, and it basically ignores it and goes from 0 across the part to the cut start position.
Any ideas? I am pretty sure it is something I or my collegue has done but I cannot find it.
Thanks n advance,
Bob
Re: Mach3 ignoring safe Z
« Reply #1 on: September 04, 2012, 01:12:20 PM »
If you attach your xml and I will see if I can find the issue.
« Reply #2 on: September 04, 2012, 01:34:23 PM »
Do you have a rapid move to safe Z programmed in the code?  Something like "G00 Z1".  If I remove them from my code, it will do exactly as you describe.
« Reply #3 on: September 04, 2012, 03:52:14 PM »
Mach3's safe Z setting has no effect when g-code is running. The machine will move exactly where the g-code tells it to.
« Reply #4 on: September 04, 2012, 03:57:35 PM »
The way I was reading it was he was pressing GoToZ and it was just going to XYZ Zero without first raising in Z and then lowering Z when X and Y got to Zero.
« Reply #5 on: September 05, 2012, 10:20:23 AM »
I thought the safe Z was doing that. So it is aspire doing this?
Well at least it gives me a place to start looking.
thnaks,
