Hello Guest it is November 01, 2026, 11:43:09 AM
Author Topic: LCam and Rhino  (Read 10029 times)
LCam and Rhino
« on: January 17, 2007, 12:52:03 PM »
Hi to all,
I design a part in Rhino V 3.0 (in mm) and I imported in LCam. I generated the g-code. When I imported in Mach3 V R2.0.036 (setup is in mm also) my design is more larger than original design.
How can I fix that?
Another question - if I jog some place in my table and regen the toolpath:
How can I "tell" the DRO to start from that point?
The mil start to cut from a point which it is in g-code
N25 G90 G80 G40 G91.1
N30 G0  Z0.0000
N35  X19.8605  Y26.3802
N40  Z0.1000
N45 M3
N50 G1  Z0.0000  F1.00
N55  X35.3117
Thank in advance
GB
Re: LCam and Rhino
« Reply #1 on: January 17, 2007, 02:53:31 PM »
You can high lite your line of code that you want to start back on and click run from here. ;D It will ask for a prep move. Click yes. Try it out with some air cuts untill you get the hang of it.
