Hello Guest it is October 01, 2026, 12:04:09 AM
Author Topic: Possible new project pending feedback on LazyCam software  (Read 34505 times)
Re: Possible new project pending feedback on LazyCam software
« Reply #10 on: August 20, 2012, 06:44:13 PM »
Another vote for SheetCAM.  We have ArtCAM, RhinoCAM and VisualMill...And I Use SheetCAM 99% of the time.  The ability to use programming logic like if...then...else, etc. in post processors makes it capable of a lot of things that the others are not.
« Reply #11 on: February 10, 2013, 12:41:26 PM »
I changed the design a bit, not using a spindle motor now. Decided to use a 1 HP conventional 110V motor and drive it with some intermediate pulleys to get the tool in the 9000-500 RPM range, built a R8 spindle housing to use the collets I already have.
It's slowly coming together...
« Reply #12 on: February 10, 2013, 01:10:58 PM »
Looking good!
« Reply #13 on: February 11, 2013, 04:22:38 AM »
Nice work,
I especially like the way that you counterbalanced the Z by putting the motor onto the backside of the machine.
Mike
« Reply #14 on: February 11, 2013, 07:29:02 AM »
Thanks.
Everything attached to the main gantry rail is aluminum except for the motor. I am mounting a 6 inch precision vice (yellow block) on the frame and a rotary head beside it. The work table is 5/8" Blanchard ground plate. The side plates are water cut 1" 6061 plate.
There is a slight issue with frame sag because of the gantry weight but it is being solved with a table brace and some center jack screws.
« Last Edit: February 11, 2013, 07:32:12 AM by oldmechano »
« Reply #15 on: February 11, 2013, 02:03:24 PM »
Good to see a nice clean and tidy wiring job :)
« Reply #16 on: March 01, 2013, 12:59:59 PM »
Got all the hard parts built... now doing cable/air/wire management, mounts for control box/laptop, then strip it down for paint.
« Reply #17 on: March 01, 2013, 01:21:22 PM »
Why in the world are you going to cover up all that eyecandy with some ugly paint?   ;D
Looking great!
« Reply #18 on: March 15, 2013, 05:28:21 PM »
Been busy with "real" work so it has been on that back burner as of late... only going to paint the steel parts.
« Reply #19 on: March 16, 2013, 06:05:22 AM »
Neat work so far, may I ask if you have a build thread on your R8 spindle that goes up to 9000 RPM's?
Do you possibly have a picture of it in pieces and showing/naming what bearings you used?
Thanks, and great work you have done-
