Hello Guest it is November 23, 2026, 10:09:44 PM
Author Topic: Problems With Mach3 under Windows XP  (Read 24470 times)
Re: Problems With Mach3 under Windows XP
« Reply #10 on: August 25, 2012, 07:12:17 AM »
Hi Red,
Thanks for the information.
I am at the point with this problem that I am in the process of wiping everything and starting again with a clean install of windows. I will probably go with the 32 Bit version of Windows 7, although I am not completely sure. I have the latest version of Mach3 installed on my development computer, so I can test run the G code as it is created. It runs with no problem. Of course, there is no printer port and no Cutter connected, which could be why it runs so well.
I will, of course, give your suggestion a go on the way to wiping everything. Maybe I will be lucky.
One way or the other, I will get it running as it should.
Thanks again.
regards,
Albert
