Hello
Guest
it is
October 23, 2026, 09:11:30 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Need to cut a radius
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Need to cut a radius (Read 9099 times)
DavidJS
1
on:
August 10, 2012, 02:57:30 PM »
Im pretty new to g-code have used it for doing straight forward things but now i need to cut a radius im not sure if ill need to use i-j-k its totally over my head then
Hope someone can help
David
Logged
Carnoustie, Scotland
Re: Need to cut a radius
Reply #1 on:
August 10, 2012, 03:45:22 PM »
Have a look at the G Code explanation that you will get if you click the G Code button on the main page of MachMill.
Logged
rrc1962
673
Reply #2 on:
August 11, 2012, 05:32:13 PM »
Or use a cam program like SheetCAM. Simple things usually fall within the line limit of the trial version. You would need to draw the arc, but SheetCAM will handle the GCode.
Logged
Print
Pages:
1
Go Up
« previous
next »
