Hello Guest it is November 27, 2026, 10:08:55 AM
Author Topic: New to cnc and looking for help.  (Read 56940 times)
Re: New to cnc and looking for help.
« Reply #10 on: August 03, 2012, 05:51:52 PM »
Take Rich's advise  8)
Id advise a larger OD cutter for the Outside cutout, that is a lot for a small cutter to do. Unless you plan on several shallow cuts, To be buried in a profile cut that long means lots of issues.  I try to Never cut deeper than the diameter of the cutter. And a cut of that length will most always result in tool breakage unless going very slow with coolant/Tap magic/ or something that will keep things cool and lubricated. The other issue is how do you plan on holding this piece?
That is why most items of this type are a stamping/ cut out in a progressive die from a long strip/coil of material.
« Reply #11 on: August 03, 2012, 06:01:50 PM »
Yes I was planning on shallow cuts. I was thinking of using double sided tape to hold it down along with some clamps along the outside or the piece.
This is just a start, I know I will be learning as I go, and the larger cutter is a good idea.
I was hoping that a small project like this I could use wd-40 to spary on the tool.
It will only be 31/2" x 21/4 approx.
Thanks for the info, This is why I am here, I knew there would be someome who knows what they are doing that would lend a hand.
« Reply #12 on: August 03, 2012, 09:38:23 PM »
Thank you! This works great. I am amazed at how well you got it the the specs. Well Done!
« Reply #13 on: October 05, 2012, 12:20:24 AM »
Were you able to make your eye patch?  If so, could you post a photo of it?  I'm curious to see
how it turned out.
