Hello Guest it is November 27, 2026, 09:01:06 PM
Author Topic: SetToolDesc problem  (Read 7783 times)
Offline TPS
  •  2,627 2,627
SetToolDesc problem
« on: July 26, 2012, 03:00:25 AM »
hi all,
tryed the example from
Mach3 Version 3.x
Macro Programmers Reference Manual
to set tool description.
Sub Main
   Dim TNum As Integer
   Dim TDesc As String
   TNum  = 1 ' want to set description for tool # 1
   TDesc = "1/4 135 degree split point drill"
   If SetToolDescription(TNum, TDesc) Then
      Message "Tool description was set"
   Else
      Message "Error setting Tool description"
   End If
End Sub
geting errormessage in VB Scripter : Sub or function not defined:SetToolDescription
any ideas how to fix ?
Thanks Thomas
Re: SetToolDesc problem
« Reply #1 on: July 26, 2012, 06:10:08 AM »
Hi Thomas
what Mach3 version are you using. This function needs at least V3.42.30
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline TPS
  •  2,627 2,627
« Reply #2 on: July 26, 2012, 08:15:56 AM »
Hi Klaus,
version is: R3.043.058, but i found the problem 5 minutes ago:
 If SetToolDescription(TNum, TDesc) Then 'this is wrong in the example
must be:
 If SetToolDesc(TNum, TDesc) Then
now it works.
regards Thomas
