Hello Guest it is November 01, 2026, 10:13:27 AM
Author Topic: Thanks to Brian & or Lazy cam Team! Please keep up the good work!!!  (Read 27239 times)
Re: Thanks to Brian & or Lazy cam Team! Please keep up the good work!!!
« Reply #10 on: February 07, 2007, 05:12:16 PM »
We are thinking about that but we need more time :(
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: February 14, 2007, 10:03:44 AM »
Hey Brian,
  Wow just checked out the new Lazy Cam Pro video...  Sweet!!  I so need that pocket menu as I am way to LAZY to do it my self!  Would love to preorder so I can get an e-mail / LCP the day its ready.  only one project on hold...  sniff sniff    ;)
  Also if there is going to be a fee how much might we be talking about and what time frame might we be looking at?
« Reply #12 on: February 24, 2007, 05:09:40 PM »
Lcam Pro will be about 75.00 and should do Lathe! IT looks like it is going to be a very good simple Cam program ;)
www.machsupport.com
« Reply #13 on: March 03, 2007, 01:01:59 PM »
Hello Brian and Art,
Keep up the good work, I'm verry pleased with Mach-3 so far.
I have my home build router working sind November 2006.
So far there where no significant problems.
I'm still in the learning curve but things are going verry well.
Most of the parts that I made on the router are balsa and lightply parts for model airplanes.
For the new LCam version I have two items for the wish list:
The first item:
Is it possible that there will be a feature for tabs?
Thus preventing that parts come out of the material while cutting.
This is also very usefull when there are fragile parts need to be cut.
So far i have been using the "Easy DXF Cam" feature for tabs from www.USBCNC.com
The second item for my wishlist is a little change at the way parameters have to be filled in for each layer.
In the current version there is the need for a little move with the mouse over the fields before a value can be added.
More usefull should be the way when you can jump for one field to another with the tab key ore a single mouse click on the field.
- Piet Versleijen
« Reply #14 on: March 14, 2007, 08:01:34 AM »
We are looking in to the tabs as a pro feature and the clicking into the fields and tabing.. that is hard because of the way that we are showing the data :( We have looked into this and could't seem to get it...
www.machsupport.com
