Hello Guest it is November 10, 2026, 07:07:56 AM
Author Topic: New Member-Look ahead question  (Read 9127 times)
« on: July 17, 2012, 03:55:36 PM »
Hello,
I have a cnc plasma table and I'm having a problem with some artistic drawings. If I draw normal parts with normal radius and lines I have no problems. Some of the artistic drawings I get have a lot of lines to make a radius. When I cut these artistic radius on some of them it beats the heck out of my machine and its not consistent. I believe I read on some forum that you can set Mach 3 to "look ahead" and this helps with the problem. I know part of it is just cutting these types of files, but curious to see if there's some solutions I haven't heard about.
John
Re: New Member-Look ahead question
« Reply #1 on: July 17, 2012, 04:30:17 PM »
Hi John,
   You might check to see that you are in G64 Constant Velocity mode instead of G61 ... Exact Stop.
There is a .doc explaining the features of each in the documentation section.
Russ
