Third party software and hardware support forums. > NC Pod
Not returning to zero
Greolt:
Disabling legacy mode in bios has made comunication more stable.
However I have a funny problem.
Set all DROs to zero, run the roadrunner, DROs not ending on zero. Gcode last move is go to zero but DROs not returning to zero.
Watching the Z axis DRO during code execution. Z spends most of the time at -0.1 and goes up for rapids returning to -0.1
Each time (or most) it returns 0.0025 different than the last. So they add up to a cumulative error by the end.
See pic for screen capture at the end of roadrunner execution.
rcrabb:
I only ran the roadrunner a few time since I got the comuncations fixed. I noticed the same thing with the Z positioning and returning to zero.
Greolt:
Glad it is not just me.
It always feels better if someone else is having the same problem. ;D
kookaburra:
Beta Team,
Art is aware of this issue and at the moment is talking with the Pod developer about it. The Pod and Mach 3 is accurate to +/- 1 step (provided you have the latest version of Mach 3 and the Pod firmware update). I will re-visit this with Art to get an update on his thoughts regarding this matter.
Brian Barker:
Set your servo time to .00087 and you should be good :)
I have been running tests and it is working well for position. you need to have the latest software on everything.
Navigation
[0] Message Index
[#] Next page
Go to full version
