Hello Guest it is November 13, 2026, 09:50:36 AM
Author Topic: Fonts  (Read 36995 times)
Offline GaryB
  •  108 108
Re: Fonts
« Reply #10 on: January 15, 2007, 01:16:40 PM »
I run ArtCam Pro for modeling and cam then I use Visual Cadd for all my architectural drawings.
Beckwith Decor Products
ArtCam Trainer
Onsrud & Custom CNC tooling Distributor
Wichita/Derby Kansas
http://www.beckwithdecor.com
Re: Fonts
« Reply #11 on: January 15, 2007, 01:19:44 PM »
I have read about artcam pro.  How is the learning curve?  Does it have good features?  I assume it can do a rotary axis with no problems?  Any limitations that you have run into?
Thanks.
dan.
Offline GaryB
  •  108 108
Re: Fonts
« Reply #12 on: January 15, 2007, 01:58:58 PM »
Dan,  I would have to say the learning curve is not that bad, just depends on an individuals computer illiteracy, but to be some what proficient takes time and work for the modeling side, drawing, cam, v-carving etc very straight forward quick and easy.
Has some of the top all round features of any package, guess I'm a little bias, there is a fews things I would prefer in the software but no limitations on my behalf. And yes you can output for an indexer
ArtCam Trainer
Re: Fonts
« Reply #13 on: January 15, 2007, 02:04:28 PM »
I use ArtCam as well. Another program you may want to look at is Vectric. It was developed by the same folks. Here is a link.
http://www.vectric.com/
Offline GaryB
  •  108 108
Re: Fonts
« Reply #14 on: January 15, 2007, 02:11:46 PM »
Good point Brett, Tony & Brian have an excellent package in their V-Carve pro and now their 3d machinist software, for the money its hard to beat
ArtCam Trainer
Re: Fonts
« Reply #15 on: January 15, 2007, 02:46:56 PM »
But I do not think vcarve has a rotary output????
Dan.
Re: Fonts
« Reply #16 on: January 15, 2007, 02:53:13 PM »
Have you talked to Tony about this?
Re: Fonts
« Reply #17 on: January 15, 2007, 02:56:56 PM »
No, I just read the web site. Didn't see anything about an A axis output.
Dan.
Re: Fonts
« Reply #18 on: January 15, 2007, 03:47:01 PM »
I look for Tony to jump in this thread at some point.
Re: Fonts
« Reply #19 on: January 15, 2007, 03:52:44 PM »
I did a search on their forum and found a post that asked about controlling a rotary axis and the answer was that vcarve pro cannot output to a rotary axis.
