Hello Guest it is November 13, 2026, 09:43:23 AM
Author Topic: Minor Threading Problem  (Read 21171 times)
Re: Minor Threading Problem
« Reply #10 on: July 15, 2012, 11:47:53 AM »
Hood, I think it would depend on the tool tip radius. John's probably sharper (smaller radius) than yours.
« Reply #11 on: July 15, 2012, 12:49:00 PM »
Hi, I did a few internal threads today and found that I needed to adjust the value to pitch * 1.3 to get proper crest form.
The insert tip even with my magnifier looks to have no radius (or perhaps so small I cant see) I also checked to see if it really was a 60 degee tip. I've checked tool offset and backlash, all good.
Still I suppose when it comes down to it, if it works don't worry about it.
John
« Reply #12 on: July 15, 2012, 12:55:00 PM »
Could well be that it is a sharp point. I use full profile tips so going from pitch to pitch the number I use will likely work out because of that.
« Reply #13 on: July 15, 2012, 01:47:28 PM »
Hi John,
The number you arrived at seems to be right based on the mathematical formula for a 60°: DOC = 0.5 x Pitch x tan60° ≈ 0.866 x Pitch ≈ 1.3
« Reply #14 on: July 15, 2012, 05:00:18 PM »
Thanks guys for the help and reassurance. I've now added a few buttons on the threading wizard to automatically fill in the X end value for the thread based on the formulas.
ATB
John
