Hello Guest it is November 13, 2026, 01:54:46 PM
Author Topic: HELP-External E Stop Requested  (Read 33713 times)
Offline dito
  •  10 10
Re: HELP-External E Stop Requested
« Reply #10 on: July 08, 2012, 06:27:51 AM »
hi
Offline dito
  •  10 10
« Reply #11 on: July 08, 2012, 07:21:40 AM »
Hi Hood
THIS:      http://www30.zippyshare.com/v/53578558/file.html
 Is the link where you can download my stuff (fast download)
« Reply #12 on: July 08, 2012, 05:33:10 PM »
There doesnt seem to be any mention of spindle control in the manual, or at least not that I could see. How is it connected?
You however do have Spindle relays enabled and set for OutPut 1, however you do not have OutPut 1 enabled (Config, Ports and Pins, Outputs)
Offline dito
  •  10 10
« Reply #13 on: July 09, 2012, 04:43:31 AM »
Yes Hood I thought about it but on the other hand, Up until your reply  I had had the user's manual  that was saying not  to switch on the output 1.
unfortunately even when I  made this:
nothin had changed.
I thought maybe I should disable "active low" for output 1?? ( but in mach tutorial on   www.machsupport.com   it is set in that way as on this pic
plus there are some buttons on the controler and the relay which seem not to effect  the machine
while e-stop button (on the controler)works
Thanks and sorry for bothering you
« Reply #14 on: July 09, 2012, 09:35:58 AM »
The buttons on the controller look like the front panel of the VFD (Spindle controller) Really you would have to find out whether the spindle is controllable by Mach as maybe it is just controlled from the front switches. The VFD may actually be needing a parameter change as it may be set up to use the front control panel rather than use external (Mach) control.
Offline dito
  •  10 10
« Reply #15 on: July 10, 2012, 01:30:19 PM »
HI
As my seller told me that their engineer is not available and thus can't answer my questions for several days
I asked her to give me a contact of a person who had bought  the same router from her,
I'm going to contact him and hope he can help.
Dito
