Hello Guest it is September 12, 2026, 10:59:36 AM
Author Topic: Galil DMC 21XX  (Read 10292 times)
Galil DMC 21XX
« on: June 23, 2012, 09:03:39 PM »
Hello Everyone,
I am currently having problems with my Home routine and slave axis using Galil DMC 21xx.
IF I use galil plugin version 4.4 the home sequence works fine, But i cannot get Axis to slave on the X Axis.
If t use Galil Plugin Version 4.5 which is I think the right plugin for this controller the slave axis works but home routine doesnt.
I hits the limit switch and stop and does nothing.
Anyone has the same problem? I would appreciate very much if you could help me with this problem. It might just be a mistake on my setup. Thank you .
« Last Edit: June 23, 2012, 09:08:31 PM by renatom »
Offline smurph
  •  1,575 1,575
Re: Galil DMC 21XX
« Reply #1 on: July 03, 2012, 12:32:11 PM »
Unfortunately, the gantry homing is not working correctly at this time.  So you are not alone.  :(  The problem is that neither Kenny nor I have a gantry machine to test on to get it working.
Steve
Re: Galil DMC 21XX
« Reply #2 on: July 03, 2012, 05:35:35 PM »
Hello Steve,
Thank you very much for your reply and Information regarding the Gantry problem on Galil DMC21XX. I have solve the problem by using each individual home inputs rather limits using them as home inputs. Thank you very much again.
Renato
