Hello Guest it is November 03, 2026, 10:35:52 PM
Author Topic: ShuttlePro  (Read 12434 times)
ShuttlePro
« on: June 20, 2012, 09:01:22 AM »
Ok, I know it the older version of the ShuttlePro, not the ShuttlePro 2,  may have been covered but my searches aren't finding what I need to know.  I just got around to setting up MACH3 on a new PC and downloaded the plugin that is on the MACH website.  I can call up the plugin to program the keys but there's no way, I can see, to program the center dial and ring.  Is there a newer plugin in out there that includes these.  I've been away from the hobby for about a year and a half due to health issues and now I can do some playing again.  Also, can someone post a photo of what they programmed their buttons to do.
Thanks so much for your help.
Re: ShuttlePro
« Reply #1 on: June 20, 2012, 11:00:29 AM »
i didn't think you could program the dials, surely you alter the setting in mach for different reolutions
Re: ShuttlePro
« Reply #2 on: June 20, 2012, 11:20:35 AM »
Agreed, if you're going to change the jogging rate in Mach 3, I believe that changes the shuttle speed as well.
I don't think there's a way to program the dials at all either.
Re: ShuttlePro
« Reply #3 on: June 20, 2012, 11:35:23 AM »
Ok, so if you can't assign them, do they just work to jog or run?
Re: ShuttlePro
« Reply #4 on: June 20, 2012, 11:37:34 AM »
the centre is a step jog wheel and will move per step, and the outer is fast jog with seven ascending rates for each direction
Re: ShuttlePro
« Reply #5 on: June 20, 2012, 11:40:21 AM »
lol, you beat me again! Here's a video that may help you set up the jog speed as you might like it:
http://www.seabreezeparachutes.com/sproject/7stepjogsetup.wmv
Re: ShuttlePro
« Reply #6 on: June 20, 2012, 01:04:17 PM »
Thanks Dave,  I'll keep that link for later reference.
