Hello Guest it is October 24, 2026, 11:04:37 AM
Author Topic: material orientation on table  (Read 9809 times)
« on: June 19, 2012, 09:56:49 PM »
Hi
I'm new at this. Just got a g 6 table with a mach3 controller.
There's a dialog box for orienting the plate on the table.
I cannot remember the steps to get to it.
Can someone please help?
Thanks for your help
Re: material orientation on table
« Reply #1 on: June 20, 2012, 06:52:50 AM »
Local System Rotated ... Degrees
On the MDI page.
Is that what you are meaning ? ? ?
Russ
« Reply #2 on: June 20, 2012, 10:02:54 PM »
Hi Russ,
    By the way, my name is Joseph.
I was handed a G6 table with a mach3 controller,
with absolutely no instructions.
From day 1 the table has malfunctioned.
We have finally worked through all the mechanical problems with the table.
While waiting on line with Canada, I remember reading something about how to orient
a piece of material on the table without having it straight with the axis of
the table. I recall the basic instructions, 1) locate 1st corner 2) move to another corner and enter the coordinates in a pop-up box telling the machine this is now the other end of the plate.
 I know this is extremely vague and I have no background to draw from.
Pretend you're talking to an absolute idiot.
 Thank you for taking the time to at least read my post.
HELP IF YOU CAN!!!!  ???
« Reply #3 on: June 20, 2012, 10:45:31 PM »
Hi Joseph,
   Here is a cool little Wizard. Might be just what you need.
Unzip it to your Mach3/Addons folder, restart Mach and it should then be in the wizard list.
Welcome aboard,
Russ
