Hello Guest it is October 24, 2026, 12:10:05 AM
Author Topic: Script Editor Font Too Small  (Read 34445 times)
« on: June 13, 2012, 10:47:26 AM »
Hey folks,
  I have no clue as to why the font is so small now when I view a script.
How can I get it back to the normal size ?
Russ
Re: Script Editor Font Too Small
« Reply #1 on: June 15, 2012, 04:00:49 PM »
Please ?
« Reply #2 on: June 16, 2012, 02:44:03 AM »
Not a clue Russ, have been trying all sorts of things to make it happen but not managed, you certainly get the booby prixe for that one ;D
« Reply #3 on: June 16, 2012, 06:23:46 AM »
I also tried Russ. No setting that i could find in Mach or Windows.
A work around may be to bump the reading glasses up to 2x! ;D
« Reply #4 on: June 16, 2012, 08:27:55 AM »
Thank you very much for your efforts men.
I've got my binoculars duct taped to my head now Rich, might need to borrow one of your cool scopes. ha ha
I have done all I know except to remove Mach and bring it all in again.
Thought maybe it was the C++ Redistributable thing, so I tried reloading that (various versions), different versions of Mach, on and on.
Will try the reload.
Thanks again,
Russ
« Reply #5 on: June 16, 2012, 09:35:13 AM »
I saw something similar last night working on a new Conversational Drill Wizard. When I would open the button code it came UP very small but as soon as I clip on it to edit it would pop back up large again. ????
Sounds like a video thing maybe.  I banged on it for about an hour looking for the cause but gave up.
Probably a windows setting like  fontsize DPI. I know that will effect the numbers fitting in the DROs.
« Reply #6 on: June 16, 2012, 09:58:22 AM »
Hey Terry,
  Editing never changes it here, stays small. Starting a NEW script is small too.
I removed all Mach and reloaded, still the same.
If I remember correctly, when first ever loading Mach, it installs Mach stuff, then the driver, then it loads some sort of redistributable Microsoft stuff.
That is evidently still installed as IT doesn't re-load during the install so I would like to remove it as well and reload EVERYTHING completely to see if it makes a difference but am not sure what to remove.
  The Control panel/ Remove Programs has 4 different C++ Redistributables. Would it be safe to remove them ? Would this initiate a more complete re-install of Mach ? Would it cause problems elsewhere ?
Not sure exactly when this happened, but it might have been about the time we were testing Mach 4 for Brian. ? ? ?
Thanks TP,
Russ
« Last Edit: June 16, 2012, 10:01:07 AM by Overloaded »
« Reply #7 on: June 18, 2012, 07:58:48 AM »
Well, I've done all I can think of and cannot get it fixed.
Deleted every Mach related that I could find, reloaded ... still the same.
No idea where that "Editor" is or what it is called. Is it in the M3 folder ? or plopped in Windows somewhere ?
Tried to get on over at Yahoo but have much difficulties with this slow connection.
If I could access the Gods, I'm wondering if they might have any clues.
This PC if working fine otherwise.
Hate to get another one set up just to fix this issue.
Thanks again .... for anything you might think I can try.
Russ
« Reply #8 on: June 18, 2012, 12:12:14 PM »
Have you tried looking at the Windows Screen configuration and changing the Font size ? From the Desktop Right click on the mouse and go configuration then find the font size setting. Standard is 96  It may have gotten bumped somehow ???
That setting will ALSO effect all the DROs. ARE your dros the correct size?
Just a shot in the dark, (;-)TP
« Reply #9 on: June 18, 2012, 12:17:25 PM »
Russ I asked over on the yahoo site . We will see what comes up.
