Hello Guest it is November 01, 2026, 08:17:47 PM
Author Topic: Coolant On at start up  (Read 8878 times)
Offline Quin
  •  34 34
« on: June 10, 2012, 10:33:20 PM »
when I initially start Mach3 and X home or Z home limit is made (2 axis machine), both mist and flood coolant comes on??
Quin
  •  9,375 9,375
Re: Coolant On at start up
« Reply #1 on: June 11, 2012, 02:07:08 AM »
Hi Quin,
It is usual to have Mach turn off all outputs (as a safety precaution) when a stop is encountered. Perhaps changing the active state (High / Low) of the outputs you use for these functions may be the way forward (reconfiguring the logic switching of the connected devices).
Offline Quin
  •  34 34
« Reply #2 on: June 11, 2012, 09:00:13 PM »
Thanks Tweakie,
Further details on the problem:
I load Mach3.  If either X home or Z home limit is active, the flood and mist are energized after about a 2 sec delay.  They can only be turned off by moving the X or Z on to the overtravel limit.  When I come off the overtravel, they come back on. when I come off either home limit they stop.  If I cycle the overtravel a couple of times, the problem clears and I can run a program normally with out further problem.
If I shut down Mach3 and restart,  the problem returns.
Is this possibly a known bug in Mach3?
« Reply #3 on: June 11, 2012, 09:06:44 PM »
I think you may have the coolant setup with the same ports/ pins as the limits or homes. Check your config.
Just a thought(;-) TP
