Hello Guest it is October 15, 2026, 10:08:25 PM
Author Topic: I need a new pc  (Read 19930 times)
Re: I need a new pc
« Reply #10 on: June 06, 2012, 01:57:00 PM »
If I went with the smoothstepper (it has two parallel ports) can it use both ports at the same time? Or should I be looking for a four axis controller?
The USB Smoothstepper has the equivalent of  2 parallel ports worth of I/O plus an extra 6 inputs on port 3.
The Ethernet SmoothStepper has 3 full parallel ports worth of I/O
If considering the Smoothstepper the Ethernet one would be the one I would recommend although it is more expensive.
Re: I need a new pc
« Reply #11 on: June 07, 2012, 12:16:19 AM »
Thanks Hood, I appreciate it.
