Hello Guest it is November 05, 2026, 10:35:30 PM
Author Topic: Gcode does not execute correctly  (Read 8685 times)
« on: May 27, 2012, 05:22:54 AM »
I am new to Wizards, so please be patient. I Looked at some wizards and then created my own that output the following Gcode. Mach gets to line 3 and just get stuck there. What am I screwing up here?
Code: [Select]
F1800
G00 Z1
G00 X0 Y0
G01 Y0.5
G01 X199.5
G01 Y2.5
G01 X0.5
G01 Y4.5
G01 X199.5
G01 Y6.5
G01 X0.5
G01 Y8.5
G01 X199.5
G01 Y9.5
G01 X0.5
G00 X0 Y0
M30
And here is the VB that creates the code
Code: [Select]
Sub Main()
DoOEMButton (169)
FeedRough = Abs(GetOEMDRO(1070))
ToolDia = Abs(GetOEMDRO(1071))
ToolRad = ToolDia / 2
XPOS = GetOEMDRO(1072)
YPOS = GetOEMDRO(1073)
SafeZ = 1 'Abs(GetOEMDRO(1079))
Length = Abs(GetOEMDRO(1080))
Width = Abs(GetOEMDRO(1075))
StepDepth = Abs(GetOEMDRO(1076))
Clearance = StepDepth * 1.5
If FeedRough = 0 Then
    Code "(MSG,Feed Rate can't be zero)"
End If
If StepDepth = 0 Then
    Code "(MSG,Step down can't be zero)"
End If
If Length = 0 Then
    Code "(MSG,Length can't be zero)"
End If
If Width = 0 Then
    Code "(MSG,Width can't be zero)"
End If
OpenTeachFile "LaserPeenScan.tap"
XStart = XPOS
YStart = YPOS
XFinal = XPOS + Length
YFinal = YPOS + Width
XToolDown = XStart
YToolDown = YStart
PassNumber = 1
Code "F" & FeedRough
DepthofPass = StepDepth
PassType = 1
XStart = XPOS - Offset + ToolRad
YStart = YPOS + ToolRad
XFinal = XPOS + Length - ToolRad
YFinal = YPOS + Width - ToolRad
Code "G00 Z" & SafeZ
Code "G00 X" & XToolDown & " Y" & YToolDown
YpassNo = 0
Do
    YofPass = YStart + (ToolDia * StepDepth  * YpassNo)
    If (YofPass >= YFinal) Then
        Exit Do
    End If
    Code "G01 Y" & YofPass
    Code "G01 X" & XFinal
    PassType = PassType * -1
    YpassNo = YpassNo + 1
        Exit Do
    End If
    Code "G01 X" & XStart
Loop
YofPass = YFinal
If (PassType = 1) Then
Else
End If
Code "M30"
CloseTeachFile
Call LoadTeachFile
End Sub
Main
Re: Gcode does not execute correctly
« Reply #1 on: May 27, 2012, 07:58:29 AM »
The g-code runs fine here.
One thing you need to add is a carriage return after the M30, or just a
Code "%"
Otherwise, the M30 won't be recognized.
« Reply #2 on: May 27, 2012, 12:49:42 PM »
Thanks Gerry,
I have a development PC that the code does not run but when I installed on my actual machine PC it worked ok. Strange??
