Hello Guest it is September 28, 2026, 11:03:44 PM
Author Topic: Fixture Save  (Read 9961 times)
Fixture Save
« on: May 26, 2012, 07:15:20 AM »
Hello World,
When exiting the program, if the work offsets have been changed since the last shut down, we are queried, "Save Fixture?".  I would like to add a button that does this any time I want.  Is this a separate function (that I have been unable to find) or is it wired to the Windows Cancel button right in the program.  I assume it is much like function 122 but with an automatic "Yes, save all".  How can I emulate this?
Re: Fixture Save
« Reply #1 on: May 26, 2012, 08:17:46 AM »
This is enabled with a checkbox in General Config, "Optional Offset Save".
I think that OEM button 122 is as close as you can get.
Re: Fixture Save
« Reply #2 on: May 26, 2012, 08:26:00 AM »
Thanks Gerry,
Do you know what actually drives the message box when shutting down the program?  It isn't a separate screen is it?  And as a secondary question being's you seem to be up on the general configs, what controls the delay at the start of a program, before movement, before spindle activation, begins.
Thanks again,
Re: Fixture Save
« Reply #3 on: May 26, 2012, 08:57:20 AM »
I believe the optional offset save is a built in function that can't be accessed.
Not sure about the delay you refer to. In Ports and Pins, Spindle Tab, there's a delay that waits for the spindle to get up to speed before movement, but there shouldn't be any other delays. Perhaps it's something in your g-code?
