Hello Guest it is November 01, 2026, 03:35:43 PM
Author Topic: Z axis inverts when posting g code from LC  (Read 22925 times)
« on: May 19, 2012, 08:44:48 PM »
OK..draw with CadStd...
export as .dxf file...
open .dxf file with LazyCam....all OK
...but when I post to Gcode...the Z axis comes out inverted....ie: cuts on the lead paths and not on the parts ! What am I doing wrong ??
Thanks... ???
Re: Z axis inverts when posting g code from LC
« Reply #1 on: May 20, 2012, 06:22:03 AM »
Your cutting directly on the line you have drawn or are you trying to do an offset from it?
The pro version is required to do offsets.
Post the LCAM file and the dxf file.
