Hello Guest it is October 21, 2026, 06:06:28 PM
Author Topic: Changing the XML file that a Screenset uses.  (Read 8986 times)
Offline btu44
  •  28 28
« on: May 16, 2012, 02:44:50 PM »
Hello,
I have made a copy of my current Screenset and its associated XML that I will use for mod testing.
How can I get the 'copied Screenset' to use the 'copied XML' and not the original XML file?
(Yes, they have been renamed)
Barry
Re: Changing the XML file that a Screenset uses.
« Reply #1 on: May 16, 2012, 03:29:06 PM »
By xml are you meaning the Mach  profile?
Not really sure what your question is as opening a profile then loading a screenset will associate that screenset with the profile. The change will only be saved when you shut Mach down though.
Offline btu44
  •  28 28
« Reply #2 on: May 16, 2012, 04:03:03 PM »
Thanks for replying.
What I did was copy and rename the .set & .xml files. Then I changed the shortcut to use these files.
After posting, I realized I should Create & Clone the in Mach3 Loader...much better.
Thanks again.
Barry
