Hello Guest it is October 22, 2026, 07:56:55 PM
Author Topic: easy motor tuning  (Read 21394 times)
Re: easy motor tuning
« Reply #10 on: May 12, 2012, 03:49:16 AM »
Thank you Rich-- I just couldnt figure how the procedure was supposed to work
Are these and similar instructions available anywhere- I cant recall seeing them anywhere in
the manual--
But you guys are a great help
thanks
fred
« Reply #11 on: May 12, 2012, 07:06:55 AM »
Fred,
Not sure what the manuals say about using the axis calibration. To lazy to have a look at them. ;D
There is a nice axis calculator in the Members Docs which one can use to do caclulations and comes in handy if one wants to compare
different parameters. Here is the link:
http://www.machsupport.com/forum/index.php/topic,16315.msg110286.html#msg110286
I also like to calculate the steps per unit , use that value and then check the axis movement to extremes ie; profile the axis for record keeping.
The profiling is done opticaly but note that i have the tools to do it that way and may be a little wierd........ :D
