Hello Guest it is November 28, 2026, 07:22:49 PM
Author Topic: Two issues to fix  (Read 12249 times)
Two issues to fix
« on: May 06, 2012, 07:51:43 PM »
1.  Router stays running regardless of "M"commands.  Where is the switch that I need to turn on/off so I can get the router to respond.  (Bosch router running off of single AC relay.)  All the axes work properly.
2,  "R,i,j,k words all missing for arcline 6295"  What does that mean?  I created the program with Vectric Cut 3D
Thanks in advance for any guidance you can send my way.......
Re: Two issues to fix
« Reply #1 on: May 06, 2012, 08:05:41 PM »
You shouldn't be seeing that error with Cut3D, as it doesn't produce g code with arcs. Can you post the code?
« Reply #2 on: May 06, 2012, 08:29:59 PM »
Yes, I'll need to get to my garage to get a copy...metal bldg no internet without a lot of hassle...I'll get back to you...BC
« Reply #3 on: May 06, 2012, 08:44:42 PM »
I wonder if the process i used to get the drawing into 3d had an effect -  used Meshcam to make an .stl file which i opened in cut 3D....
« Reply #4 on: May 06, 2012, 09:17:28 PM »
Why??? MeshCAM can do everything that Cut3D can do and more.
You might want to contact Vectric about that error. The code was missing a G01.
« Reply #5 on: May 06, 2012, 09:44:54 PM »
I am relatively new to this and I bought meshcam to render drawings to 3D and I guess I was fixated on using Vectric.  I will try more of Meshcam's features.  Thanks for the
heads up...BC
