Hello Guest it is November 05, 2026, 10:01:12 PM
Author Topic: ATC automatic tool change M6 macro Dynomotion Kflop+Kanalog  (Read 41843 times)
I've written a macro for an ATC carousel type using an Ac motor. Each motor rotation indexes the carousel by one position.
I can drive it CW or CCW. There's two inductive sensors, one fro the Ac motor rotation ( i++ or i--) and one for the carousel Home Position.
The carousel is sent in tool change position by an air cylinder, the only driven axis is Z.
I tried to use it and have a scripter compile error.
If someone would tell me what's wrong?
Thanks for your attention,
J.
Here's the code:
Sub Main()
'Global variables declaration
NewTool = GetSelectedTool()
OldTool = GetCurrentTool()
'Flow sequence
'Compare between actual tool and requested tool
call Compare
'Carrousel air cylinder position check : Home, in Mvt and ToolChange
call AirCyHome
call ToolChangerPos
'Move to Z tool position and wait until position reached
call Z_TcPosition
'Spindle Home Sequence
call SpindleHome
'Activate air cylinder valve to put old tool back to carrousel
call OldToolBack2TC
'Spindle: Tool Unclamp
call Unclamp
'Go to safe tool change Z coordinates
call Z_TcPosition
'Spindle: Tool Clamp
call Clamp
'Sequence to determine the least travel to move for TC, CW or CCW
call LeastTravel
'Turn CW or turn CCW integrated in above Sub
call OldToolBack2TC
call Unclamp
call Z_TcPosition
call Clamp
'Air Cylinder Homing
call AirCyHome
'Store new tool as actual tool value
Call SetUserDRO (1200,NewTool)
SetCurrentTool( NewTool )
' Compare between actual tool and requested tool
Function Compare() As Integer
   Dim Compare As Integer
   If NewTool = OldTool Then
   Compare = 1
   Else
   Compare = 0
   End If
End Function
Function ToolChangerPos() As Boolean
   If IsActive(INPUT1)>IsActive(INPUT2)Then 'We are at Home Position
   ToolChangerPos = 0
   TCMove = False 'We are stopped
   ElseIf IsActive(INPUT1)<IsActive(INPUT2) Then
      ToolChangerPos = 1
      TCMove = False
      Else
      ToolChangerPos = -1
      TCMove = True
   End If
End Function
sub AirCyHome()
   DeactivateSignal(OUTPUT8)
   AirCyHome=IsActive(INPUT1)
end sub
Sub Z_TcPosition() As Integer
   code("G53")'Move in Absolute Machine coordinates
   while(IsMoving())
      Sleep(100)'temporisation entre while++
   Wend
   code("G00 Z-116") 'Z value as to be checked for exact match with carrousel height
   while(IsMoving())
   Wend
   Z_TcPosition=1 '1 quand en position pour Tool Change
end Sub
Sub SpindleHome()
   ActivateSignal(OUTPUT1)'activate spindle indexing for ToolChange
   while(IsMoving())'Do nothing while spindle is rotating
      sleep(100)
   wend
   'Maybe necessary to invoke a case select for tooling choice if more than 10 tools
end sub
'Spindle Release
Sub SpindleRelease()
   DeactivateSignal(OUTPUT1)
end sub
'Put old tool back to carrousel
sub OldToolBack2TC ()
   If Z_TcPosition=1 then
      Activate Signal(OUTPUT8)'Move carrousel via the air cylinder to reach the tool change position
   else
      call Z_TcPosition
   End if
end Sub
Sub Unclamp()
   If IsActive(INPUT2)'Sensor indicates that carrousel is at tool change position then
      ActivateSignal(OUTPUT9)'Release the tool, unclamp
   End If
end Sub
Sub Clamp()
   DeactivateSignal(OUTPUT9)'Grip the tool, Clamp
end Sub
Sub ZUp_TcPosition() as Integer
   ZUp_TcPosition=0 'var init
   code("G53") 'Move in absolute machine coordinates
   while(IsMoving())
      Sleep(100)
   code("G00 Z-35")'Move to the safe Z position for tool change
   while (IsMoving())
      sleep(100) '0.1sec delay between loops
   wend
   ZUp_TcPosition=1
end Sub
'atp = Actual tool position, rtp = Requested tool positon
Sub LeastTravel()
   NTool = 10 ' Number of tools changer holds
   CWPos = GetSelectedTool() - GetCurrentTool() ' Assume a CW move
   If CWPos < 0 Then ' CWPos < 0 ==> rtp < atp
      CWPos = CWPos + NTools
   End If
   CCWPos = NTools - CWPos
   If CWPos < CCWPos Then
      call CW()
   Else
      call CCW()
   End If
End Sub
'Rotation CW
Sub CW()
   dim x as Integer
   dim CTPos as Integer 'Carrousel Tool Position Relative to OldTool Position
   CTPos=0
   ActivateSignal(OUTPUT10)'Turns the AC Motor On
   Do until IsActive(OEMTrig1)
      Sleep(50)
   loop
      for x=0 to CWPos
         If IsActive(OEMTrig1) then
            x=x+1
            While IsActive(OEMTrig1)
               'Wait for OEMTrig to de-assert
            End While
         End If
      next x
      CTPos=x
   DeactivateSignal(OUTPUT10)
End Sub
'Rotation CCW
Sub CCW()
   dim y as Integer
   CTPos=0
   ActivateSignal(OUTPUT11)
   Do until IsActive(OEMTrig1) 'Turns the AC Motor On
      Sleep(50)
   loop
   for y=0 to CCWPos
      y=y+1
         End While
      End If
   next y
   CTPos=y
   DeactivateSignal(OUTPUT11)
End Sub
Main
Re: ATC automatic tool change M6 macro Dynomotion Kflop+Kanalog
« Reply #1 on: May 06, 2012, 01:56:50 PM »
Try;
While IsMoving()
Wend
Instead of
While (IsMoving())
Wend
« Reply #2 on: May 06, 2012, 02:07:43 PM »
I removed all occurrences and it doesn't give better results.
I also tried a very simple test by making calls to the clamp and unclamp subs only, without any change in the error message.
I'm a newbie in macro programming so I probably missed something but what...
J.
« Reply #3 on: May 06, 2012, 02:40:50 PM »
I didn't read the whole thing, and I'm no expert, but here's another issue. This:
  while(IsMoving())
      Sleep(100)
   while (IsMoving())
Should be this:
Code "G00 Z-35"
While IsMoving()
Wend
You don't need the Sleep() in the While IsMoving().
« Reply #4 on: May 06, 2012, 03:49:23 PM »
Hi Gerry,
I tried that and other changes like a mix with(out) parenthesis :
IsMoving()<>(IsMoving())
code("G00 Z-35")<>Code "G00 Z-35"
This doesn't gave me any results.
I will try without using calls, maybe I'm not using them well:
Call Statement
Call funcname [(parameter(s)]
or
[parameter(s)]
Activates an Enable Subroutine called name or a DLL function with the
name name. The first parameter is the name of the function or
subroutine to call, and the second is the list of arguments to pass to the
called function or subroutine.
You are never required to use the Call statement when calling an
Enable subroutine or a DLL function. Parentheses must be used in the
argument list if the Call statement is being used.
Example:
Sub Main ()
Call Beep MsgBox "Returns a Beep"
End Sub
Source: Language Reference page 45 Cypress Enable for Mach
So if someone has a good idea, he's welcome.
Thanks for help,
J.
« Reply #5 on: May 06, 2012, 05:43:00 PM »
Everything I told you is correct. Yuo probably have multiple issues, and you'll need them all fixed before it will work.
I usually add msgbox statements to track down trouble areas.
« Reply #6 on: May 06, 2012, 08:09:49 PM »
Hi Gerry,
I started debugging this evening, more to come tomorrow.
I suppressed some functions and have to try some tests.
Good suggestion about the msgbox.
I'll keep in touch.
J.
PS: I had some corrections made by other sources and tested both () solutions.
« Reply #7 on: May 07, 2012, 08:57:09 AM »
It appears mach3 is having problems in the way you are using the Function and sub calls. I cleaned up all the obvious problems but still get errors on the function calls and sub calls.  Not being a programmer can't be much more help.
I can get it to work BUT it sure is NOT a pretty way to do it. (so I am told(;-) ).
IF you can't get it worked out I will dive into it with you and see IF we can get it working.  THERE are VB WIZARDS on here so hopefully they will chime in on this one.
« Last Edit: May 07, 2012, 08:59:34 AM by BR549 »
« Reply #8 on: May 07, 2012, 07:55:17 PM »
I started to make many debugging tests and files to see what ans why.
Here is an example of code, partial since there's not all the functionalities.
If I add the Sub Main() and End at the end it's not working, syntax error, and if I don't, it's the same....
For clarity reasons I'll post another one message with other code related issues.
J.
Dim Z_TcPos As Integer
Dim ZUp_TcPos As Integer
'Flow sequence
   End
   Else
End If
'Call AirCyHome
'Call SpindleHome
   Sleep (500)
   While(IsMoving())'Do nothing while spindle is rotating
      sleep(100)
   Wend
' Show the user the state of the OUTPUT #1 input
   If IsActive(OUTPUT1) Then
   MsgBox "OUTPUT #1 output is active"
   Else
   MsgBox "OUTPUT #1 output is inactive"
   End If
'Call Clamp
'Call LeastTravel
   End If
   Dim x As Integer
   Dim CTPos As Integer 'Carrousel Tool Position Relative to OldTool Position
   CTPos=0
   Do Until IsActive(OEMTrig1)
      Sleep(50)
   Loop
      For x=0 To CWPos
         If IsActive(OEMTrig1) Then
            x=x+1
            Wend
         End If
      Next x
      CTPos=x
   Else
   'Rotation CCW
   Dim y As Integer
   CTPos=0
   Do Until IsActive(OEMTrig1) 'Turns the AC Motor On
      Sleep(50)
   Loop
   For y=0 To CCWPos
      y=y+1
         Wend
      End If
   Next y
   CTPos=y
   End If
'Call Z_TcPosition
   While(IsMoving())
   Wend
   While(IsMoving())
   Wend
   Z_TcPos=1 '1 quand en position pour Tool Change
'Call OldToolBack2TC
   If Z_TcPos=1 Then
      ActivateSignal(OUTPUT8)'Move carrousel via the air cylinder to reach the tool change position
   Else
      Call Z_TcPosition
   End If
'Call Unclamp
If IsActive(INPUT2) Then'Sensor indicates that carrousel is at tool change position then
'Call ZUp_TcPosition
   ZUp_TcPos=0 'var init
   While(IsMoving())
      Sleep(100)
   Wend
   While(IsMoving())
   Wend
   ZUp_TcPos=1
'Call Clamp
'Spindle Release
'Call AirCyHome
   While (Not(AirCyHome))
   Sleep(100)
   Wend
Call SetCurrentTool( NewTool )
« Reply #9 on: May 07, 2012, 08:01:49 PM »
This is basically the same code than before, excepted that I use Functions rather than subs. It's a little bit better, I can have Z moves but nothing more.
Normally the OUTPUT1 should be activated but there's no actions, MsgBox confirms the statement.
Something strange occurs, my call sequence isn't respected, I can check that using more MsgBox.
If I try to use the functions inside the Main Sub, this is not working at all: Syntax error, this is also strange to me.
Jerome
Sub Main()
'Flow sequence
   End
   Else
End If
Call AirCyHome
MsgBox "Carrousel air cylinder position check"
Call SpindleHome
MsgBox "Spindle Home call"
Call Clamp
Call LeastTravel
Call OldToolBack2TC
Call Unclamp
Call Z_TcPosition
Call Clamp
Call AirCyHome
End Sub
   ToolChangerPos = 0
      ToolChangerPos = 1
      TCMove = False
      ToolChangerPos = -1
      TCMove = True
   End If
End Function
Function AirCyHome() As Integer
End Function
Function SpindleHome()
      sleep(100)
   Wend
'Show the user the state of the OUTPUT #1 input
Else
End If
   Call ToolChangerPos
   Call ZUp_TcPosition
   Call OldToolBack2TC
   Call Unclamp
   Call ZUp_TcPosition
End Function
Function Z_TcPosition()
   While(IsMoving())
   Wend
   While(IsMoving())
   Wend
End Function
'Spindle Release
Function SpindleRelease()
End Function
Function OldToolBack2TC ()
   If Z_TcPos=1 Then
   else
      Call Z_TcPosition
   End if
End Function
Function Unclamp()
   If IsActive(INPUT2) then'Sensor indicates that carrousel is at tool change position then
   End If
End Function
Function Clamp()
End Function
Function ZUp_TcPosition()
   While(IsMoving())
      Sleep(100)
   Wend
   while(IsMoving())
   wend
   ZUp_TcPos=1
End Function
Function LeastTravel()
   End If
      call CW()
   Else
      call CCW()
   End If
End Function
'Rotation CW
Function CW()
   dim x as Integer
   CTPos=0
      Sleep(50)
   loop
      for x=0 to CWPos
            x=x+1
            Wend
         End If
      next x
      CTPos=x
End Function
'Rotation CCW
Function CCW()
   dim y as Integer
   CTPos=0
      Sleep(50)
   loop
   for y=0 to CCWPos
      y=y+1
         Wend
      End If
   next y
   CTPos=y
End Function
Main
